Replaces a single data value at the specified location in an array variable with another value. |
| Array |
Enter the array variable containing the array in which you want to update a value. |
| Position |
Select the array position at which you want to update a value:
Index |
If you selected the 'At Index' option for the Position property, enter the index location (as a literal value or an integer variable) at which you want to update the value. For a maximum permitted array length of 50 values, the index must be in the range -50 and 49. A minus value counts backwards from the end of the array and facilitates updating values that are near the end of the array. As an example, in an array containing 5 values, the indexing is as shown below:
Specifying an index of 2 or -3 updates value C with another value (say, X) to give the following array:
Note: if you provide an index that exceeds the number of values in the array, then no update takes place. |
Update Value |
Enter the value that should overwrite the current value (a literal value or a variable matching the data type of the array). Note: a date value must be provided as a variable and not as a literal. |
This is taken if a value was updated at the specified index location. |
Not Found |
This is taken if the specified index location did not exist. |
This is taken if an error has occurred. |
