Where a script has been committed more than once resulting in multiple versions of the script, you can activate a previous version to make it the active version. The previously active version is then marked as 'inactive'. If the script is assigned to an entity such as a storm access point for incoming calls, it is the active version that is always invoked.
Select the LOAD SCRIPT command from the menu at the top right of the screen.
Select the inactive script version that you want to activate, and then click the Set Active button. This is the version that will run when the script is next invoked.
