Sets an agent group status to active or inactive. |
This allows managers to dial-in and temporarily prevent communication from being routed to a group of agents who are away from their desks.
Static Agent Group/ Use Dynamic Agent Group/ Agent Group |
Select the agent group to enable or disable. Either select the group from a drop-down list:
Or, specify the agent group using a variable:
Enable/Disable |
Select the desired action. |
This is taken if the status has been set. |
Not Found |
This is taken if the agent group is not found. |
This is taken if an error has occurred. |
