Assigns a value to a variable. |
Destination Variable |
Enter the variable that will store the assigned value. This must not be of type date. |
Enter the value to assign (a literal value or another variable). If the type does not match the destination variable, it is converted at run time. See Variable Conversion, below.
There are constraints that you must observe when assigning object and array variables. See Constraints below.
The action cell can be used to covert one type of value to another. The following conversions are supported:
Destination type |
Source type |
Float or integer |
String |
Converts a string of numeric characters to a numeric value. Useful for converting a captured numeric string to a monetary value. |
Boolean |
String |
Converts zero to false and all other values to true. |
String |
Float or integer |
Converts the number to a character string. |
Boolean |
Float or integer |
Converts zero to false and all other numbers to true. |
String |
Boolean |
Converts true to 1, and false to 0. |
Float or integer |
Boolean |
Source Variable Type |
Destination Variable Type |
Object |
This must be an object of the same type as the source variable. For example, if the source variable is an object of type 'CustomerDetails', then the destination variable must also be an object of type 'CustomerDetails'. Each member value of the source variable is then copied to each member of the destination variable. |
Array |
This must be an array of the same data type as the source variable. For example, if the source variable is an array of data type 'String', then the destination variable must also be an array of data type 'String'. The destination array becomes an exact copy of the source array. |
