Listens for a sound on a connected line and branches accordingly. |
Use it to confirm that the called party is on the line.
Timeout Duration |
Enter the duration after which, if no sound has been detected, execution takes the Timeout exit point. Enter this as a whole number (integer) in milliseconds. This must be a value that is provided as a literal preceded by =, or a variable of the correct type. |
Sound Duration |
Enter the duration that the sound should reach for the action cell to exit the Sound Detected exit route. Enter this as a whole number (integer) in milliseconds. This must be a value that is provided as a literal preceded by =, or a variable of the correct type.
Sound Detected |
This is taken if a detected sound has reached the duration specified in the Sound Duration property. |
Timeout |
This is taken if no sound is detected within the timeout specified in the Timeout Duration property. |
