Inserts an ASCII character at a specified location (offset) in a string. |
For example, inserting the character 'C' in the string 'ABD' at an offset of 2, results in the string 'ABCD'.
Character code |
Enter the ASCII value of the character. See ASCII characters and codes. |
Destination |
Enter the string variable containing the string that will take the insert. |
Offset |
Enter the offset location after which to begin insertion (a literal value preceded by =, or an integer variable). For example, a value of 2 means that the inserted character will occupy position 3 in the updated string. A value of 0 inserts before the first character. |
