String Manipulation Action Cells
This category provides functions for manipulating string variables. You can do things such as search, extract, validate, format, replace, and append strings, and also manipulate URI query strings.
Description
Extract String
Extracts a sequence of characters from a specified location (offset) in a string variable and stores the extraction in another string variable.
Find String
Searches for a sequence of characters in a string variable and branches accordingly.
String Length
Measures the character length of a string.
Format String
Combines variables collected by the script into a single string variable.
Find and Replace
Replaces a sequence of characters in a string variable with another sequence of characters.
Append String
Extends a string by joining another string to the end of it.
Insert String
Inserts a string at a specified location (offset) in another string.
Insert Character
Inserts an ASCII character at a specified location (offset) in a string.
Convert Case
Converts all of the alphabetic characters in a string variable to either upper or lower case.
Parse String
Retrieves parameter values from a URI query string.
Build String
Inserts values into a URI query string.
Regex Match
Uses a regular expression (regex) pattern to search for a specific string or patterns of text in a string variable and branches accordingly.
Full action cell list
