Sends an open question to the customer and stores the answer in a variable. |
Note: the action cell is available to ASK: Survey scripts only.
Question |
Enter the question as a string value (as a literal preceded by =, or a string variable). |
Answer |
Enter a string variable to store the answer provided by the customer. If you want to report this value in a historical report in storm VIEW, create an extended record in VIEW that contains data fields for this as well as any other answers collected by the script, and then populate those data fields using the Set VIEW Data action cell. |
Timeout |
The number of minutes to wait for the customer to provide an answer before exiting along the Timeout exit point. |
Alias |
Enter a friendly name that will be seen by the customer, or leave blank if you want the customer to see the name of the FLOW script. |
Timeout |
This is taken when the timeout value specified in the Timeout property is reached. |
This is taken if there is an internal error. |
