Starts a stopwatch or resumes a paused stopwatch. |
Use this in conjunction with a Read Stopwatch action cell to measure the time taken (to the nearest one tenth of a second) for the script to progress from one point to the next. For example, to measure the time a caller spent listening to a prompt or the length of a transaction.
Stopwatch |
Use the drop-down list to select an existing stopwatch that you want to restart from 0 seconds or that you want to resume from when it was paused by a Read Stopwatch action cell earlier in the script's flow. Alternatively, use the
Stopwatch Start Mode |
Select 'Reset Stopwatch And Start' to start the selected stopwatch from 0 seconds.
Or, select 'Resume Stopwatch Without Reset', to resume the selected stopwatch.
