Copies content from one audio file to another. |
This allows a user in your organisation to dial in and change a prompt quickly. For example, to overwrite a Welcome message with a disaster recovery message during an emergency.
Select Media List/ Use Dynamic Media List/ Source Media List/ Select Media Item/ Use Dynamic Media Item/ Source Prompt |
Choose the audio file to copy. See also, Use Media in a Script. |
Select Media List/ Use Dynamic Media List/ Destination Media List/ Select Media Item/ Use Dynamic Media Item/ Destination Prompt |
Choose the audio file to receive the copy. See also, Use Media in a Script. |
This is taken when the prompt has copied successfully. |
This is taken if any media files configured could not be located. It is also taken if a system error occurs causing the new prompt to remain uncommitted. The original prompt remains in effect. It is recommended that you design the script to loop around to allow the caller to reattempt the operation. |
