Retrieves the identity of the agent and the date and time at which they handled the last SMS, email, or social media interaction with the contact. |
The action cell does this by seeing if the originating addresses (or conversation references) in the script’s earlier interactions with all contacts matches the address or reference of the current contact. On finding an interaction, its arrival date and time, and the user ID of the agent who serviced it are retrieved.
When used in conjunction with other action cells, you can use the user ID to provide continuity by routing each contact to the agent with whom they previously interacted (the ‘preferred’ agent). The retrieved date and time can be used to limit the routing for recent interactions only.
See Routing an Interaction to the Same Agent for an example.
Search Method |
Select the search method to find the last agent to service the customer. 'Origination Identifier' uses the SMS number, email address or social media account name; 'By Conversation Reference' uses the SMS number or email thread identifier, or, for social media, the ID of the message to which the new message is replying. |
User ID |
Enter an integer variable to store the user ID of the agent who serviced the matching interaction. |
Date |
Enter a date variable to store the date and time time of the matching interaction. |
Found |
This is taken if an earlier interaction with the origination ID or conversation reference was found. |
Not Found |
This is taken if an earlier interaction with the origination ID or conversation reference was NOT found. |
