Increments a value stored in a variable by 1 and then branches according to the new value. |
This is useful for repeating certain actions a specified number of times. For example, you might allow callers to enter a valid DTMF digit three times, and then route them elsewhere on the third incorrect entry.
Counter |
Enter the user integer variable containing the initial value (typically 0) to increment each time the action cell runs. |
Exit Value |
Enter the value that must be reached by the incrementing value for execution to take the Greater than or equal to exit point. This can be a literal value or another variable.
Less than Exit Value |
This is taken when the incrementing value is less than the exit value. |
Greater Than or Equal to Exit Value |
This is taken when the incrementing value has reached or exceeded the exit value. |
