Plays a recording captured by a Record action cell. |
Note: do not use this action cell to play a recording that was made by a Record action cell earlier in this script or in a parent script.
File Name |
Enter the string variable containing the name of the recording. |
Recording Played |
This is taken if the recording is played. |
File Not Found |
This is taken if the recording could not be located. |
This is taken if the recording did not play. |
