Generates a random number in a specified range. |
It can be used, for example, in conjunction with a Select Case action cell to route callers according to the value of the generated number.
Lower limit/ Upper Limit |
Enter an integer value in each field (as a literal preceded by =, or an integer variable). |
Result |
Enter an integer variable.
