Runs a subsidiary FLOW service. |
See also, Implement a Subsidiary Script.
Choose from the current list of services/ Use a variable to specify the service |
Select the subsidiary service to run by choosing from a list:
Or by entering a string variable:
Use this section to build a list of variables for passing values that the subsidiary service is configured to recognise (via its Start action cell).
Input Variables |
In the Name field, enter a label for the parameter to pass (this must match the parameter in the subsidiary script). In the Value field, provide the value to pass (a literal value or a variable). Note: a date value must be provided as a variable and not as a literal. Click ADD to add the Name and Value pair to the list below.
Use this section to build a list of variables for receiving data returned by the subsidiary service.
Output Variables |
In the Name field, enter a label for the parameter that is being received (this must match the parameter in the subsidiary script); In the Value field, provide the variable to store the value. Click ADD to add the Name and Value pair to the list below.
Resume |
This is taken if the subsidiary service ran without error. |
This is taken if the subsidiary service encountered a run-time error. |
Not Found |
This is taken if the subsidiary service could not be found. |
