Retrieves data from memory, one row at a time, then passes it to the next action cell (such as Format String) for processing. |
Use this after a Database Query, Execute Query or DATA MANAGEMENT action cell has been used to perform a 'Select' query for retrieving data from a database table. The action cell performing the query populates a file in memory with the results and optionally returns a value indicating the number of rows found. The query populates the variables defined to hold returned values with values taken from the first row found.
Query Statement |
Select the query whose results you want to fetch. |
Result Row |
Optionally, enter an integer variable to hold the row number of each returned result. Row numbering begins at 1. |
Record Selector |
Select one of the following:
Record Number |
This is displayed if the Record Selector property is set to 'Explicit'. Select the row to fetch. |
This is taken when the required row has been fetched successfully. |
End of File |
This is taken when every row has been fetched successfully.
This is taken if the query's results could not be fetched. |
