Combines variables collected by the script into a single string variable. |
You can then use the combined string to do the following, for example:
Variable |
Enter the string variable to hold the combined string. |
Each format specifier is a placeholder for any arguments listed in the Value property. Enter any plain text along with any % format specifiers shown below where: %d is a variable of type Integer, Boolean or a Date element. %s is a variable of type String. %[.x]f is a variable of type Float, where .x is an optional precision specifier for rounding the number to x decimal places In addition to user variables, you may also include system variables, global string variables, and CDR variables. |
Argument |
Use the field and ADD button to build the list of values to populate the placeholders in the order in which they appear in the format string. |
You can reorder the list by dragging and dropping items.
Variable values substituted in the format specifiers might result in, "Dear John, your account is overdue by £100.46. Please pay by the end of 05/2018. We will send a final reminder in 5 days."
This is taken when cell execution completes. |
