Disconnects a voice call with a selected disconnection reason, which is sent to the public switched telephone network. |
The action cell allows you to explicitly reject an incoming call whilst sending a disconnection reason to the network (you select a SIP-based disconnection reason, which is mapped internally to Q.850 reason codes). Disconnecting a call using this action cell is useful where, for example, the script has determined that the caller is unlikely to be routed to an agent or to another resource in a reasonable time frame.
You should invoke this action cell at a point in your script where the call has not been answered. However, if another action cell has already answered the call, then the Disconnect Call action cell will still disconnect the call but override your selected disconnection reason with a 'Normal' disconnection reason. The action cells that answer calls are: Answer Call, Voicemail, Play Media, Record, Data Capture, Menu, Play Expression, Prompt Re-record, Detect Sound, ASR Menu, Add to Prompt Queue, Wait for Prompt Queue, Play Recording, Enrol Voice Model, Check Voice Model, Verify Voice Model, Gather Card Number, Gather Security Code, Submit Transaction, TTS, Speech to Text, and Machine Agent Voice.
The action cell does not have configurable exit routes because the call ends when this action cell is invoked.
Disconnection Reason |
Select the disconnection reason to send to the network. These apply if the call has NOT already been answered by the script.
Note: if the call has already been answered by the script, Q.850 cause 16 (normal call clearing) is sent to the network. |
None.
